Using SKYPE on Samsung phone
Hey Mash quizon!
The answer of your question is "NO". The reason behind this answer is that, Skype has not introduced software for Java enabled mobiles. Your mobile Samsung S3770 is java enabled. Skype has introduced its software for only Android and OS mobile. Samsung Galaxy is android phone and you can use Skype on this mobile. Similarly IPhone is OS mobile that can support Skype.
So if you want to use Skype on your mobile then you must have an Android or OS mobile.
I hope that i have cleared your view regarding Skype for your Samsung S3770.
Thanks
Mash, you cannot download Skype on your Samsung S3770. Skype has been released for IPhones, Windows Phones and Androids. You can see Skype supported mobile platforms here: https://www.skype.com/en/get-skype/ .
Yes, using Skype on your mobile phone will increase its battery consumption. Since Skype is an application that requires continuous background running on mobile's WiFi or 3G/ 4G data, it will consume mobile's battery efficiently.
