I have Lenovo laptop with windows 7 and was wondering if it is possible to adjust fan speed with smart noise sensing option? If it is possible to use smart noise Lenovo for adjusting fan speed then can anybody tell me how? Any kind of help would be appreciated.
Using smart noise Lenovo for adjusting fan speed.
Hi there Eliza, I have read your query regarding the Lenovo smart noise control. Yes, smart noise control button enables you to adjust fan speed everytime you use your PC. By clicking this button, you can easily adjust it between normal and silent mode. Plus, it also has the dust cleaning feature which can be enabled by holding the button for three seconds. I hope this works for you.
