Using smart phones as credit cards.
Will it be possible to use smart phones as credit cards anywhere in the near future? With NFC enabled phones will it be possible to use our phones  to pay for purchases and use it as a credit card?
Dear Fern bonnie,
You want to know that, will it be possible to use smart phones as credit card anywhere in near future.
Here is your answer with some information.
Now days it is possible to use smart phones as credit card. Near field communication NFC enabled mobile phone could be used as credit card. NFC method of communication, like blue tooth, uses a chip to transmit a high frequency signal up to 10cm away. This is the main concept of using of smart phones as credit cards.
Iphones and android phones can be used as credit card.
The way of using smart phone will help the people in future. There are more advantage will be added in smart phones in future to make easy life.
I hope my answer will make you happy. Thank you.
