Using VirtualDub using the AC3 ACM Codec at 3/2Channels error message
I was creating a 1/3DvDrip of one of my DVDs… The Created file had the following attributes…
But on trying to re-encode or 448kbps using VirtualDub using the AC3 ACM Codec at 3/2Channels, I get the following error message. Have you any idea to fix it? Thanks.
The audio codec cannot compress the source audio to the desired format.
VirtualDub Error
Error initializing audio stream compression:
Check that the sampling rate and number of channels in the source is complete with the selected compressed audio
format.
OK
Answered By 0 points N/A #174061
Hi Robert L Hammon
This error occurs when the input format is multi-channel and VirtualDub that the encoder must be support the multichannel format. MP3 encoder says that it was not handled the so much coolness. So VirtualDub shows empty list.
You checked that you decode the AC3 to stereo. You must select the Audio->Conversion in VirtualDub menu and set the Channels to stereo.
Regards From
Whitaker Sorg
