I love traveling. Last week I was in the Abu Dhabi for a business meeting.
The problem is I can’t access some of the websites and forums I usually go to.
The webpage shows that the page is blocked. Â
Is there any way to bypass this using VPN?
Please teach me how.
Renault
Using VPN in the Middle East
Service provider has blocked some of the content. However, it is possible to evade such Gateway defenders if you will use a bypass proxy server (web based). But If such proxy servers are also blocked then you are in a trouble.
Try this solution:
1. Log on to www.jumboproxy.net
2. Type the name of your desired web and click surf.
Alternatively,
1. Install ultrasurf software on your PC and then try to access your desired web from your internet explorer.
I hope it will serve the purpose.
Renault
I use www.mamakvpn.com. Very good speed and gets me to all blocked websites like facebook
