I need to send two (2) applications so that when one is selected the other one reacts.
I want a calendar outlook (populated in one application) to keep posted if a person is selected from a file (based from other application).
I have been thinking to do this for sometime and have hit a dead end as the existing information/knowledge is not adequate. I don't know how to use the WDS system to send the two applications or how to make the action essential to do this. Where will I’ll be connecting using the person UNID.
Any help will be highly appreciated.
Using WDS system in Outlook
You can be able to use multiple outlook profiles for by different users on the same windows logon session, but then there is a problem associated with that. The data that the users are using will be kept via private passwords, and this will be done on their outlook profiles. In case a user shuts down outlook before moving away from the computer, then they will be insecure because someone else will be able to simply load the WDS and thus have access to the user’s data that is in outlook, and thus posing a security issue. You can contact the Microsoft support for further assistance because it important for the security of the system to be enhanced.
Regards
Thompson Locker
