USSD activator plugin for ‘Huawei 1550 modem’
Hi There,
I use monthly Internet package 1 GB for browsing and downloading.
So I need to count how many megabyte I use daily. So USSD is the best tool, which I used.
But today after opening modem software I cannot see it. So I reinstall it. But It not be show into the modem menu.
It has a trouble. Please fix my problem.
Answered By 0 points N/A #92866
Gmadeleine,
When you reinstall USSD into your Windows, you would need to re-register the shell32.dll included in the USSD program code for it to work again.
Follow these simple instructions to get it registered in the windows registry.
Step 1. Click on START button > Click on run
Step 2. Open DOS prompt using CMD ( in windows 7 type CMD in the Search box in the Start Menu )
Step 3. Go to C:windowssystem32
Step 4. Type: "regsvr32 shell32.dll"  to re-register USSD
Step 5. Restart your PC.
Happy Computing.
