I have downloaded the ustream installer but whenever I try to install it this error is always appearing, and Idont know that QTCF.dll file, can anyone help me on these?
Ustream Produce.exe – System Error
The program can't start because QTCF.dll is missing from your computer.
Try reinstalling the program to fix this problem.
Ustream producer system error qtcf.dll
This problem usually occurs during an incomplete installation of a program and I think this is what happened with your application. Since the problem is with a missing QTCF.DLL file, there is a website where different DLL files can be downloaded. I visited the site and I was able to find your missing file there. This is an immediate remedy for the problem but it doesn’t guarantee that it will work after downloading and copying the file to your system. To download the QTCF.DLL file, you may visit files starting with q.
There is another way of fixing the problem without having to download anything from the web. You just simply need to do another clean installation of the program to restore any missing files that your previous installation encountered. Uninstall Ustream then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the application again then check if this fixes the problem.
