Alan Wuest
20 points
Posted on - 05/12/2012
This is the third time I have been trying to install UT3 on my computer. On the time that the installation is almost complete, I always get the error message on the picture:
Unreal Tournament 3 Error
Error 1935. An error occurred during the Installation of assembly component
{94CB24AD-52FB-DB5F-A01F-C883B9A1E1BE}
OK
Can someone help me fix this bug?
UT3 game error during installation
I have replaced the image with a better one, sorry for that
Hy,
You attached a picture in your above question. But this picture quality is so low, so I cannot understand the error message. For this reason i am unable to read your error message.
Ok, No problem. I am giving you some information regarding this type of issues. Generally we got error message to install any game for the low configuration system. If your system can not meet with the all requirements of this game then you cannot install that game in your computer.
If your graphics can not support game resolution then you may get error to install.
You may get error for the corrupt or damage game disk.
Thanks
First of all, the issue may occur if you have some third-party programs or background programs running during the UT3 installation. I suggest that you disable those programs temporarily such as registry cleaner. Just check what's running on the background and end it for a while. Another way to fix this is to install the latest .NET Framework version from the Microsoft Website.
Download and install .Net Framework 4 Web Installer
Lastly, if you are an XP user, try the solution below:
Go to C:Documents and SettingscomputernameApplication DataInstallShield Installation Information and then remove everything from that path. And then reinstall UT3 again.
For Vista users:
Go to C:Program FilesInstallShield Installation Information and then remove everything from that path. When done, install Unreal Tournament 3 again.
