Utility of network analyzer internet speeds meter
Hello, I am using a broadband connection. Bandwidth Meter Online Speed Test is required to know the performance of the connection. Actually, I want to know about the utility of network analyzer internet speed meter. I want to get expert advice.
Answered By 30 points N/A #164198
Hi Gary Jamie,
Hope this finds you in good health. There are numerous options you can get from a top notch Network Analyzer available in the market. I am going to give you some basic but very important thing a network analyzer can do to your internet network below.
1. It captures all data passes through the network for analyzing. Tech guys called it sniffer in short.
2. Analyze, interpret & convert into human readable format.
3. Show the result in chronological format.
4. Best in the class even block & track down any intruder to prevent infiltration.
5. Can helps to develop a standard for network security by the result.
6. Track & isolate malicious network usage.
7. Can use as a monitor & track down tool for DoS attacks.
So, a network analyzer works as a 360 degree overview of a network & helps to secure network a great deal. It helps to analyze network & taking preventive security measure to remove the vulnerability.
We can understand that it has lots of utility which we simply can't ignore.
Hope that helps to enhance your knowledge at least a bit.
Thanks & Regards,
DBD
