Utilizing scroll bar controls in Visual Basic 2015
20 points
Posted on - 04/10/2015
Hi!
I want to create a program using scroll bar controls. What are the commonly used properties of scroll bars? What are the commonly used scroll bar control in VB? What is the function of “borderwidth” in VB? What are the controls that I need to include in my form? Can you explain to me the lines and or declarations that you use for me to better understand how the program flows and works? Can you change the color properties of a shape while using the scroll bar? Thank you!
