How to validate and find one word domains which are available. Is there any online provider that will help me to find one word domains that are available. I have a set of 50 one words that I need to validate. Is it possible to validate all words at a single point. Please suggest.
Validating and find one word domains
Hi Scott
There are lots of online web hosting companies that provide online domain name checker. The function of that checker is to test if your desired domain name is still available or if it is already taken.
Here are some of the best and most famous web hosting provider that embeds the domain checker in their website.
All you need to do is key in the domain name you want, and then select for the domain name extensions, then click “check availability”.
I hope this helps.
