The value i enter appears with two decimal places in Excel…
When i enter a value it is appearing with two decimal places. For an example when i enter 186 it appears as 1.86. What is wrong and how can i fix?
You need to format the cell. Please follow the following steps to change the format of cell :
Step 1 : Â Right Click on the column where you want to change the format. Â Select "Format Cell" from pop-up menu.
Step 2 : Click Number Tab, and select Number under Category, then select Decimal Places : 2 and click OK.
This will solve your problem. Still if you find problem please reply me.
Great! Is this how it works? please see my image.. Its working now..Formatting cells in Excel is really interesting. Thank you for the solution.
