Value Of The Router With Best Parental Controls With Features As Well
Hello, notify the price for the router with best parental controls and state some features for the same as well and thanks for solving too and reply ASAP.
Hey, the router with best parental controls can be bought over the online portals through and will cost you approx Rs 6000 or higher as per the product you go with and will can some features too like listed below:
• It will have a dual band of 2.4 GHZ and additional 5 GHz too
• There’s a advance security level for the wireless WPA2 also
• The Ethernet ports will be of 4 Gigabits respectively.
• There will be a 90 days warranty too
• The speed will be 4.3 times faster as well.
If you’re looking for a router with parental control features, try checking this:
Skydog – though this is not the fastest and lacks some advanced features, it is a great watchdog over the content that your children might access on the internet. This is a newcomer to the router industry and a product of a Kickstarter campaign. This device allows parents to manage the contents not only by device name but also by individual users.
It also comes with a pre-configured “black lists” of adult websites and those with questionable contents. It also allows parents to schedule the internet hours of their kids when they are allowed and not allowed to surf the web. Skydog supports Wi-Fi 802.11 b/g/n, four LAN ports, WPA2, and WPA2-Enterprise. For more info, go to Skydog Smart Family Wi-Fi Router.
