ValueError for Miro says not allowed to raise maximum limit
Hello friends,
I am literally fed up with this error message in Miro. It was a clean install no errors, may be problem with other application or operating system. I googled the problem found miracle happened to some. Don’t find any solution? Please help me to resolve this error and enrich me with ideas. Thanks.
Title: ValueError: not allowed to raise maximum limit
Miro Error
Miro Error
An unexpected error has occurred during execution of the main script
Answered By 590495 points N/A #187520
When downloading Miro, make sure you downloaded the correct version and it supports your current Mac OS X version. To make sure you are using an up-to-date version, download the latest version from Miro 6.0 for Mac. This version requires Mac OS X 10.6 Snow Leopard and higher. There are also older versions of Miro for previous versions of Mac OS X.
For Mac OS X 10.4.11, download Miro 3.0.3. For Mac OS X 10.5 Leopard, download Miro 4.0.6. If you have other versions of Miro on your computer, you can either remove it or just keep it before installing the latest version. If you don’t remove the old version and you install the latest version, it will ask you to replace it with the new one.
When this happens, select Replace during the installation. Miro is a cross-platform application that can be installed on Windows, Mac, and Linux. If you want to install it on other operating systems, visit Other Operating Systems for Miro. For Windows users, Miro 6 supports Windows XP, Windows Vista, and Windows 7.
