Various errors when connecting to other computers on network using Windows 7
Hi community,
I am receiving this error:
Error code: 0x80070035, the network path was not found
While trying to connect to any other computer (running Windows 7 Ultimate) on my network. I owned another computer with Windows 7 Ultimate, and it does not suffer from this problem. Firewalls are unable to perform on all computers.
Pings are fine on all computers. Ping by name is possible.
While trying to connect via IP address, I receive this error:
Error Code: Error0x80004005 Unspecified error
So please help me with correct suggestions.
Answered By 80 points N/A #96240
To solve the issue with error code 0x80070035 network path was not found on Windows 7 you may try to click START, and select the CONTROL PANEL and then go to DEVICE MANAGER. From there please click on NETWORK ADAPTERS, then on VIEW, and select the SHOW HIDDEN DEVICES.
You will then get the expanded view with a long list of number MICROSOFT 6 to 4 ADAPTER. Right click and select the DELETE option on all except on 1 of them. You must do it one at a time and I understand that this will take some time but it’s important so that you’ll know which of these lists are causing the problem.
Once only one is left you need to restart your computer. Hopefully, the above steps will also help you solve the other error message you are getting which was Error0x80004005 Unspecified error.
