Various functions of php dir tree and its compatibility with other programs
What are the various functions of "php dir tree" and expedite and how its useful in maintaining our directory?
PHP directory tree is a function which helps you to create valid XHTML nested list of some specific directories. This script runs on java script which further helps to collapse and expand the entire list. It is very easy to implement. Java scripts runs on one line of code.
You can also run this in browsers which don't support JavaScript.
It is customizable with CSS and helps to produce valid, semantic XHTML.
It works on:
internet explorer, Firefox, Opera and few others.
PHP directory tree and expedite helps you to speed up the process and it is very easy to use with less complications.
Notifications
