Various Other Steps Of Receive A Fax Without A Fax Machine As Reference
Hello, notify the steps for receive a fax without a fax machine in the Macintosh in stepwise for the better reference only. Reply asap and thank you too.
Hey, the steps or receive a fax without a fax machine in the Macintosh is as follows:
• First open the document you need to fax the same.
• Next ion the file menu , select the print options
• Next click the PDF option form the print menu appeared.
• Now manually enter the Fax number of the sender.
• Next in the option of modern box choose the internet modem to send the fax.
• Next click the preview button to vie the fax
• Later click on send and it’s done successfully.
Notifications
