Various Steps For Replacement Cartridges For Hp Printers In Stepwise
Hello, notify the steps for replacement cartridges for hp printers in stepwise for the reference only and thank you for solving as well and reply soon too.
Hey, the steps for replacement cartridges for hp printers is as follows:
• First turn off the printers by pressing the power button manually
• Now open the top lid of the printer
• You will have to wait till the time it moves to the right hand side.
• Next press down the cartridge and slide it over upwards and remove it.
• Next replace the new ink with the old one and place it properly.
• Also hold the ink as a copper strips on the bottom side
• Next you can slide the ink to the cartridge upward and place it
• Lastly close the cover and it’s done.
