Various Steps For Scan Router For Open Ports In Stepwise
Hello, notify the steps for the scan router for open ports and its steps too and thanks for solving the same and reply ASAP for it too
Hey, to scan router for open ports normally enter the IP address of the router and then the start end the end ports too and click for the normal scan or the advance scans too. Wait for a while and its done successfully. Below show the steps for it:
• First manually open the control panel
• Next go for the windows firewall
• Select the advance setting and its links
• Now select the inbound rules too
• Now the port on first screen appears
• Select the TCP or the UDP
• Manually enter the port and it’s done.
