Dutta Jube
20 points
Posted on - 01/09/2017
Notify the steps for this computer is protected by a password authentication system in step wise for the easy reference only and thanks for solving too.
Various steps for this computer is protected by a password authentication system as reference.
Hey,
This computer is protected by a password authentication system can be done to both the systems as well as on the specific laptops too. It helps to maintain the double security to the system as well. Below shows the steps to remove the same:
• First you need to reboot the machine from the BIOS screen by pressing F2
• Now enter into the system and access the BIOS
• Now manually navigate to the security > passwords
• Now select the password
• Now the password status will be changed to not set.
