Various Steps Of Reset Dell Inspiron Laptop To Factory Settings In Stepwise
Hello, notify the steps for reset dell inspiron laptop to factory settings in stepwise as a reference and reply asap too and also thank you for solving too.
Hey, to reset dell inspiron laptop to factory settings follow the below steps as follows:
• First you need to restart the computer and go for the boot options
• When the system is restarting just press the F8 button to get started with the booting
• Next manually select the repair computer Cour option
• Now go for the keyboard layout and select it
• If needed login with the admin users as well.
• Next click for the ok button
• Next in system recovery options select the startup repair.
• It’s done successfully.
