Various Steps Of Restore Samsung Laptop To Factory Settings In Stepwise
Hello, notify the steps for restore samsung laptop to factory settings in stepwise as a reference and reply asap too and also thank you for solving too.
Hey, to restore samsung laptop to factory settings follow the below steps as follows:
• First you need to restart the computer and go for the boot options
• When the system is restarting just press the F8 button to get started with the booting
• Next manually select the repair computer Cour option
• Now go for the keyboard layout and select it
• If needed login with the admin users as well.
• Next click for the ok button
• Next in system recovery options select the startup repair.
• It’s done successfully.
In computers, I don’t think there is a factory reset option similar to an Android phone. If you want to restore the system back to when you first install the operating system, the best way to do it is to format your hard drive and install Microsoft Windows again. There is no option that will restore the system or operating system back to factory defaults.
If you don’t want to install the operating system again, another possible way is to uninstall all the programs you installed manually. But even if you do this, there will still be remnants left in the registry and in the hard drive.
