Various Steps Of Windows 8 Pro To 8.1 Pro Upgrade In Stepwise.
Hello, notify the steps for the windows 8 pro to 8.1 pro upgrade in stepwise for the guidance too and revert asap as well and thank you so much too.
Hey, the steps for the windows 8 pro to 8.1 pro upgrade are as follows:
Microsoft Windows 8.1 is not a new version of the Microsoft Windows operating system. It is simply a Service Pack for Microsoft Windows 8. For users who will be installing Windows 8.1 for the first time, you need to check the system requirements and verify that your computer meets those requirements.
System specifications for Windows 8.1 are pretty much the same with Windows 8. If your computer can run Windows 8, you can run Windows 8.1. Microsoft Windows 8.1 requires 1 GHz or faster processor with PAE, NX, and SSE2 support; 1 GB RAM for 32-bit and 2 GB RAM for 64-bit; 16 GB free space for 32-bit and 20 GB for 64-bit; and Microsoft DirectX 9-compatible video card with WDDM driver.
Some of the enhancements in Windows 8.1 include:
