I want to download YUI, as I am doing a JavaScript project, but I can’t seem to find a trustworthy website that helps me to do so. Any suggestions on how to get the authentic version of it and more than one along with the version would be of great help.
Various Steps On How To Download YUI
You can get the authentic version of YUI 3.1x on GitHub. There are around three versions that are available there so you can choose the one that.
You can also use the GET utility at “yuilibrary.com” which makes it to dynamically load JavaScript and CSS resources. If you go to the website, it will show you a couple of steps to be followed to use YUI.
If you want the jar files for YUI 2.9 or then you can visit “java2s.com”. Not only will you get this version but also from version 0.2 to 1.x. All these are jar files.
If you still want, archived files and documentation for YUI 2, which is no longer in use since 2011, you can visit “https://yui.github.io.”. Here, you can get all the documentation and zip Archives for version 2.2.x to 2.9.0.
I would recommend not using YUI 2 for your project but you can go ahead and search these websites to download the authentication version of YUI.
