Various Steps On How To Fix A Code 43 Error Usb In Windows.
My Computer is unable to recognize any external device and shows the error code 43 with the message as shown below. Can anyone tell how to fix a code 43 error usb(refer the pasted image)?. Thanks, in Advance.
Answered By 0 points N/A #294481
The error code 43 is related to device drivers. Try the following methods to resolve it
Method 1
Open Device Manager from settings or use search tool.
Double click on the Universal Serial Bus Controller.
Select the device from the list and uninstall its drivers.
Restart your computer and visit the Vendor website and download the latest.
Method 2
From Control Panel go to Advance Power Settings.
Select the USB Settings, then click ok disable button. Save the changes, enable it after restarting your computer.
