Various Symptoms Of Fatal Application Error 2120
My active window is frequently crashing down. Could this be the fatal application error 2120? What are the common symptoms of this error? Reply asap.
Fatal application error 2120 is quite common among Windows users. The following are the most common symptoms of this error.
If you are using QuickBooks on Windows 8.x or higher operating system and it keeps crashing, make sure your computer meets the requirements. If you are using QuickBooks Desktop Enterprise, it supports Windows 7 Service Pack 1, Windows 8.1, and Windows 10 both 32-bit and 64-bit. For servers, it supports Windows Server 2008 R2 Service Pack 1, Windows Server 2012 R2, and Windows Server 2016.
It requires 2.4 GHz or faster processor, 4 GB RAM, and 2.5 GB free space. Since your screen doesn’t look like Windows 7, you should update to Windows 8.1 from the Windows Store if you are using Windows 8. If the version you are using is available in 64-bit and you have 64-bit Windows 8, download and install the 64-bit version of QuickBooks.
