Various Ways For Opening Zip Files In Windows And Its Brief
Hello, notify about how to opening zip files in windows and state in brief for the same as well. Thanks for solving and reply ASAP.
Hello, the opening zip files in windows is used to send the file to other remote desktop and also it compresses the file size and the data is more secured as well. Also you can give the password for the zip file if there’s an important files you want to transfer. In windows the same feature is used and below shows its steps for the same:
• First you need to go to the zipped folder and then you will need to drag the file to other location
• The file will be extracted to the specified locations.
• Next unzip the file and it will extract all the data
• If password protected manually enter the key and continue.
