VB Script for changing WINS and DNS on remote machines
Dear user,
You can copy this code and paste it in your VB project. You will need WMI to use this code:
' IMPORTANT !!!! Change these constants !!!!
Const STR_SERVERS = "server1 server2 "Â ' Enter your servers here, separated by a space
Const STR_NEWDNS1 = "192.168.1.1"
Const STR_NEWDNS2 = "192.168.1.2"
Const STR_NEWWINS1= "192.168.1.3"
Const STR_NEWWINS2= "192.168.1.4"
Do
   cKeuze = MakeChoise( "Choose: Report or Change (R/C)?" )
Loop until cKeuze = "C" Or cKeuze = "R"
WScript.Echo
If( cKeuze = "C" ) Then
   Change( STR_SERVERS )
Else
   Report( STR_SERVERS )
End If
WScript.Echo( "Check out https://www.activexperts.com/ for more samples and components" )
Sub Change( strParamServers )
   arrServers = Split( strParamServers, " " )
   For i = 0 To UBound( arrServers )
      ShowDnsWins arrServers( i )  Â
      Do
         cKeuze = MakeChoise( " Change DNS/WINS and reboot (y/n)?" )
      Loop until cKeuze = "Y" Or cKeuze = "N"  Â
      If( cKeuze = "Y" ) Then
         SetDnsWins arrServers( i )     Â
         RebootServer( arrServers( i ) )
      End If
      WScript.StdOut.Write( vbCrlf )
   Next
End Sub
Sub Report( strParamServers )
   Next
End Sub
Sub ShowDnsWins( strServer )
   strWinMgmt = "winmgmts:{impersonationLevel=impersonate}!//"& strServer &""
   Set objNICs = GetObject( strWinMgmt ).InstancesOf( "Win32_NetworkAdapterConfiguration" )
   WScript.StdOut.Write( strServer & ": " & vbCrlf )
   For Each objNIC In objNICs
      If objNIC.IPEnabled Then
            WScript.StdOut.Write( " " & objNIC.Description & ": " & vbCrlf & "   " )
              n = 1
            For Each strDns In objNIC.DNSServerSearchOrder
               WScript.StdOut.Write "DNS" & n & ":" & strDns & " "
               n = n + 1
            Next
      End If
   Next
End Sub
Sub SetDnsWins( strServer )
   WScript.StdOut.Write( " Set DNS for NIC: " )
         objNIC.SetWINSServer STR_NEWWINS1,STR_NEWWINS2
         objNIC.SetDNSServerSearchOrder Array(STR_NEWDNS1,STR_NEWDNS2)
         WScript.StdOut.Write objNIC.Description & " "  Â
      End If
   Next
End Sub
Sub RebootServer( strServer )
   Set OpSysSet = GetObject("winmgmts:{(RemoteShutdown)}//" & strServer & "/root/cimv2").ExecQuery("Select * from Win32_OperatingSystem where Primary=True")
   WScript.StdOut.Write( " Reboot: " )     Â
   For Each OpSys In OpSysSet
      WScript.StdOut.Write OpSys.Name
      OpSys.Reboot()
   Next
End Sub
Function MakeChoise( strMesg )
   WScript.StdOut.Write(strMesg)
   WScript.StdIn.Read(0)
   strChoise = WScript.StdIn.ReadLine()
   MakeChoise = UCase( Left( strChoise, 1 ) )
End Function
Check out this website for more help:
https://www.activexperts.com/files/vbscript-powershell-component/manual.htm
Hope this will help you.
Thank you.
