Vboxdrv software is not installed in the Machine
The “virtualbox-dkms” software is installed before now. “Sudo modprobe vboxdrv” explained that vboxdrv software is not installed in the machine. I installed the package again. On the other hand it gives similar error. After that I uninstalled and installed virtualbox again by the side of all helpful packages.
However it gives a similar error till now. Will somebody assist me with explained procedure to get on working?
Kernel driver not installed (rca-1908)
Please install the Virtualbox-dkms package and execute ‘modprobe vboxdrv’ as root.
Failed to open a session for the virtual machine Win XP
The Virtual machine ‘WinXP’ has terminated unexpectedly during startup with exit code 1.
