VBS to monitoring folder older then a specific date
I want a Script in VBS to monitoring folder older than a specific date. I am using Windows XP, please help me by providing the Script.Â
Hi Jessica,
Here is a VBScript you can use if you want to delete files that a certain folder contains. This script deletes files only if they are an hour or more than an hour older. This is actually a good script because you can configure it you want longer hours or days.
A disclaimer: I do not own this code. I got it from http://halfloaded.com/ uploaded by one of their programmers/bloggers.
I give you a script below which works great for deleting department subfolders of \servernameterminatedusers older than 3 years, but unfortunately that becomes a little bit of a problem when the user folders contained within are newer than 3 years.
VBScript: Attached
Though it has a little bit of a problem, I wish it may be helpful for you.
Thanking you.
Franke Mary
