isabross
Posted on - 02/17/2012
I've recently upgraded VCenter from 2.5 to 4.1. Everything seemed to be working great, except that I have experienced errors when creating host profiles. I haven't noted any problems with VCenter or the database, but when I try to log on to the VCenter machine, I get the following error message.
A Kerberos Error Message was received:
on logon session
Client Time:
Server Time: 18:0:5.0000 9/10/2010 Z
Error Code: 0x7 KDC_ERR_S_PRINCIPAL_UNKNOWN
Extended Error: 0xc0000035 KLIN(0)
Client Realm:
Client Name:
Server Realm: EVERCORE.LOCAL
Server Name: MSSQLSvc/<server name>.<domain name>.local:1433
Target Name: MSSQLSvc/<server name>.<domain name>.local:1433@<domain name>.LOCAL
Error Text:
File: 9
Line: e2d
Error Data is in record data.
To the experts here, please help me out with my problem.
Thank you very much!
A general system error occurred: Error retrieving the field PROFILE_NAME
Error Stack
Call "HostProfile.UpdateReferenceHost" for object "hostprofile-902" on vCenterServer"
VCenter: Error when creating host profiles
The problem you are telling is that you are receiving a message from the server when you are doing something on the server, so, you should try this one you should check it out whether what are the following relations you are facing to the person? The problem in your server is that your server is not working properly. You need to resolve this solution and you have to do this, you will follow the instruction given to you by the start of the server.
If you follow those instructions you will able to solve this problem. If still not resolved, then replace your server there might be a problem in your server and you need to solve those problems and have to do something’s which will help you in solving such situations, then you will find that your server will working properly.
isabross
You are right there is a problem with my server. Thank you for sharing your thoughts.
It helped a lot.
