I get the following error message when I click on "View Table(s)" in VEDA-BE. How can I avoid this annoying error message? Have any idea to fix this weird error message? I extremely need your assistance. Help me. Thanks.
Error!
Veda_BE
5
Invalid procedure call OR argument
points
Veda_BE error when trying to view table
Hello David!
Your problem is for the “EXE” file that was used to launch the application. Something inside is misconfigured so it is showing this error.
Re-install the program. It will be the best option if you can get the latest version.
Also, if you don’t wish to do so, download this beta “EXE” file. Replace the old one with this one.
This will solve your issue.
