VELLEMAN PIC Programmer K8048/VM111 failed.
I’m using VELLEMAN PIC Programmer K8048/VM111. And it programs a 16F628 properly for the first time.
But when I erase the code and wanted to re-write it again, an error appears.
Error:
Write Error at:0000
Wrote:292D
Read:0000
No amount of re-erasing (is that a word?!?!) helps, it's as if erasing the initial code has somehow killed the chip.
It recognizes its presence, but it fails to write anything to it.
Also the Device ID comes up as 3FFF, which it didn’t before.
Any idea what’s going on here?
Thanks in advance.
Answered By 590495 points N/A #145336
If this is the first time it happened with your application, try restarting your computer then try it again. If this doesn’t fix the problem, try verifying the code again by hitting on the Verify button of the program.
If the chip is attached on a programmable bread board, quit the program first then disconnect the board from the computer. Next, remove the chip from the bread board then re-attach it to the computer and then start the program.
See if it detects anything on the board.
Quit the program again then disconnect the board from the computer. Attach the chip again on a different location on the board then connect it to the computer. Start the program again and then check the chip.
