Verify proper AD installation(active directory)
I am new to this technology.How we can verify whether the Active directory installation is proper or not?
Hello lewis,
I have read your question and got a complete and detailed answer for you. I am sure this will helps you to completely resolve your problem and gave you a proper outline for your solution.
Following is the link by visiting this you will be able to get rid on the problem.
https://support.microsoft.com/en-us/help/298143
Hope so this helps.
Thanks
Hello Lewis
If you want to know whether Active directory installation is proper, please follow below mentioned steps
Check the SRV records in DNS server.
After you installed Active Directory, DC will register SRV records in DNS
Use net share command to verify the SYSVOL folder
Verify database & log files
NTDS.DIT, edb.*,Res*.log
Verify below mentioned active directory objects like users, computers & foreign security principles are created in ADUC
