Verizon’s NFL mobile apps problem
NFL mobile app still gives an error message when I tried to use it on the Samsung Galaxy Nexus, it refuses to work and it shows a error message. Please someone tell me how can I get rid of this error message and use the NFL mobile apps?
NFL mobile is not currently supported on this device.
Best Answer by Hathy greave
Answered By 0 points N/A #131267
Hi Luker,
I think by doing what I say now you can get rid of it, try:
First of all go under the application and forcestop the NFL and clear its all data.
Switch the mobile off and on again. Can you see the problem again?
I think you get rid of it now.
Cheers
Hathy  Greave
Answered By 0 points N/A #196272
Hi!!
NFL mobile apps are now actively block root users or active users. It is because of  hackers capturing broadcasting and also videos. Most of the users are not satisfied with this precaution. It may not include tablets too.
