Will version iOS 6.1 Beta 4 firmware support my iPhone 4. if so, please advice where to download it. If you will be able to provide a trustable download link, that will help me.
Also let me know whether it is possible to get this done without a Developer Account?
This build is compatible with iPhone 4. Once you access the link you can able to see the link particular to iPhone 4 particular for GSM or CDMA. That’s it. I hope it was useful for you to download iOS 6.1 beta 4 on A4 devices.
To learn if iPhone 4 will be supporting iOS 6.1, here are the specs. The Apple iPhone 4 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public and released on June 2010 measuring 115.2 x 58.6 x 9.3 millimeters and weighing 137 grams.
iPhone 4
It is built with glass front/back with stainless steel frame and scratch-resistant glass back panel. It uses micro-SIM card. It has IPS LCD capacitive touchscreen display with 16M colors at 640 x 960 pixels screen resolution. It is protected with Corning Gorilla Glass with oleophobic coating.
It ships with iOS 4 upgradable to iOS 7.1.2 powered by 45 nm Apple A4 chipset, 1 GHz Cortex-A8 processor, and PowerVR SGX535 GPU. It doesn’t have support for microSD. It runs on 512 MB RAM with internal storage available in 8 GB, 16 GB, and 32 GB capacities. The primary camera supports 5 megapixels with f/2.8, 1/3.2″, 1.75µm, and AF featuring HDR and LED flash.
It supports 720p video recording at 30 fps. The secondary camera supports VGA with video-calling over Wi-Fi only and 480p video recording at 30 fps. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, and USB 2.0. It has built-in accelerometer, gyro, proximity, and compass sensors.
The pre-installed Safari web browser supports HTML5. It runs on non-removable Li-Po 1420 mAh battery with standby time up to 300 hours on 2G and 3G. Talk time is up to 14 hours on 2G and 7 hours on 3G. It is available in black and white colors. To update your phone to the latest iOS supported by your device, download the latest iTunes.
1....
