Version of a Multi-language install4j uninstaller
I want to know the version of a multi-language install4j uninstaller. I want to configure or have this program to have the ability to select or set languages at run time. First there’s a need for me to buy and install the correct version.
Answered By 60 points N/A #139031
Hello Karengsam,
install4j version  4.0 has introduced new major features, which includes the “Multi-language installers” feature.
Multi-language installers feature have the ability, which allows user to select or set the languages at runtime.
By default it takes the language from “Display Language” settings in “Region and Language” windows control panel
From the version 4.0 onward you will get this feature.
The current version of install4j is 5.1.5.
Install4j is not a free product. You need to buy the product license to get a full access to its features.
There are two editions available for install4j
  1. Multi-platform edition
  2. Windows edition
You can download the product from their site link
And get the evaluation key to get an access to a trial version.
You can get the evaluation key here
Thanks,
Alisha B Stone
