Hi There!
I scan my whole computer regularly. Yesterday after finishing scan process.
A message will came. It says: Very important! .dll file missed. So please recover the .dll file immediately or you can lost your some saved data.
Remove Shared Component
The system indicates that the following shared file is no longer used by any programs and may be deleted.
D:\WINNTsystem32ZoneLabsvsruledb.dll
If any programs are still using this file and it is removed those programs may not function. leaving this file will not harm your system. If you are not sure what to do you should select the No to All button. Do you want to remove the shared file?
But windows run perfectly every times. Which .dll file is missed? Why it is missing? How can I recover it? Please tell me with best answer.
NeoTech
Very important! Missing .dll files
Nelson,
This dll file pertains to the virus information database for your Zone Alarm application. Usually this dll file can be restored by reinstalling a new version of Zone Alarm. (Download Here)
Happy Computing,
This error massages shows which .dll is missing. It calls “vsruledb.dll”.
It is missing may be for one reason but there are many reason for missing this .dll file. It is a dll file that uses more than one application program at a time. So when you install software or run a program they always check this dll file.
That’s why its so important. Also for this reason this dll file is overwritten and restored many times by running programs. Some times they can not restore it perfectly. When it happens your antivirus indicates it as a corrupted file and removes it at the time of scanning your computer.
To solve this problem you need to install this missing dll. You can Download “FixMyDLL” Software. Here you can find it http://www.dlldll.com/vsruledb.dll_download.html
Nelson,
And u Just Follow this link and download it and check your dll problem.
I Think sure your problem is solved
Regards & Thanks
Vinit Panchal
