Very Strange Error In NetBeans.
I am Java Developer and also used many JAVA tools for example JDK, JRE and JDeveloper. But now I download NetBeans from internet and install it in my system. Now I want GUI (Graphical User Interface ) Form. For I this purpose I go to file menu and Select New and then Select one Category then select its type such as JFormDesigner Form and then click at Next Button but same window appear again. This is Very Strange and confusable error for me. Any one tells me its solution.
Very Strange Error In Net Beans.
That may be a temporary problem that is causing the application to malfunction. If you have been using it before without such a problem occurring then you will need to try the following workaround:
Close the application.
On your computer press ctrl + alt + del to open the task manager.
In the task manager window, click the process tab.
Close any process that the java tools application is running.
After that restart the computer and see the response.
But in case the problem started immediately you installed the application, then I will suggest that you just carry out a complete reinstallation of the program.
-Thompson Locker
