VFP TreeView example [ActiveX controls that ships with Visual Studio]
Hi Friends, I am studying Visual Fox Pro by my own. I would like to know about Tree View, ActiveX controls that ships with Visual Studio. Please do the needful for getting me VFP TreeView example, so that I can understand VFP TreeView in a better way. If there is any online tutorial that will also help. Thanks
Best Answer by Margarete Burch
Answered By 0 points N/A #167836
A tree view is a kind of graphical user interface that displays hierarchical information vividly. Each node has multiple sub-nodes. The nodes represent items. They can expand to review sub-items, or contract to hide them. If you want to learn the coding of Tree View in visual fox pro, you can see some code examples on the Internet. I suggest you type in Google "Visual Fox Pro Tree View sample", or "VFP tree view sample", I'm sure you'll find many. The best way to learn is to read the code.
