VFS 004 scanner not working with omni vision super cam
Hey everyone,
I can not install the VFS 004 scanner I recently purchased. I calibrated the images but I get the error message "Please connect Omni Vision Super Cam" I get no confirmation so I don't think it calibrated properly but I can't be sure. I've tried an uninstall with no change.
Answered By 5 points N/A #173851
Check the scanner and camera section. Remove any instances of it. Delete if from the device manager if it is in there., Control panel / system / hardware / device manager. It may not be there but if it is just deleted. Go to add and remove programs in the control panel , uninstall the software for the scanner.
Try using the different USB port. It seems the scanner is only compatible with a high speed USB port 2.0
