This VGA is enough to play games Pro Evolution?
Asked By 210 points N/A Posted on -
I want to upgrade the VGA but confused select which one.
My current computer specs:
  • Processor Intel Pentium IV 2 GHz.
  • Motherboard Asus P4-S533-E.
  • RAM 256 VGEN Apacher 1 GB PC 2700 & PC 3200.
  • VGA Ge Force 2MX 64 MB AGP slot.
I want to replace the VGA support and the latest Pro Evolution game Need For Speed ​​(no hang or drop out). My budget only $ 115.
Best Answer by kelin_smith
Answered By 10 points N/A #82629
Dear Panghaidar,
After viewing your system specification, it is not enough to change only your VGA support for playing latest Pro Evolution Game Need for Speed. Below are the minimum requirements of Latest Need for Speed game.
  • OS – Windows XP (SP3) / Vista (SP2) / Windows 7.
  • Processor – Intel Coreâ„¢2 Duo 2.0 GHz / AMD X2 64 2.4 GHz.
  • Memory – 2 GB.
  • Hard Drive – 7 GB.
  • DVD Drive – 8 SPEED.
  • Video Card – DirectX 9.0c Compatible 3D-accelerated 512 MB video card with Shader Model 3.0 or higher.
  • Sound Card – DirectX 9.0c compatible.
  • DirectX – Version 9.0c or 10.0c.
Regarding your VGA issue, you can purchase ATI HD3 Series or NVIDIA GeForce 8 series card for playing these types of games. I personally recommend you NVIDIA GeForce 8400 GS graphics card.
Cheers Kelin.
Answered By 0 points N/A #82630
Hi I'm henry computer network technician i read your issue about your AVG upgrading. Must better you change it into NOD32 anti-virus so that your computer work faster.
Download NOD32 32bit for windows XP:
The computer SPEC for Need For Speed game.
  • RAM 512 VGEN Apacher 1 GB PC 2700 & PC 3200.
  • VGA Ge Force 2MX 128 MB AGP slot.
Thank you i hope you will enjoy your Need for speed game.
Henry
