Viber messaging services on PC
I am a fan of the viber free messaging service on mobile and recently while using the app, I noticed that there is a desktop version. I was wondering how it works because in the phone the viber software uses the sim phone number as the base for transmission but on desktop how will it work?
Answered By 0 points N/A #188456
Mary! Because of users so much interest in mobile apps like what's app, Viber, snap chat, etc. App developer starts working on a PC version of their apps. And they have succeeded. Basically, in PC these apps use certain software which connects your mobile phone to your PC or after activation your messages, call will divert on your computer instead of mobile when you are logged in from the computer.
You need 'BlueStacks App player' for this.
Download Viber by using 'BlueStacks'
Go into the search bar and type Viber and press 'Start Download' button
After download, run Viber by clicking on the icon
Press 'continue' on the next screen, enter your valid mobile number and press continue.
An activation code will sent to your mobile phone enter the code in the tab and click on 'Enter Viber' button.
Now your Viber starts working on the PC.
Enjoy!
Answered By 10 points N/A #188457
You can use Viber on your PC by downloading Viber For Windows.
If Viber is installed and activated on your phone, then only Viber For Windows will work.
Steps:
Be sure that your computer meets the software and hardware requirements.
1. Download and install Viber for windows desktop.
2. Run it.
3. You will proceed forward only if you accept the license agreement.
4. Click Yes if a Dialog box appears asking whether Viber is installed on your phone.
5. Click Continue after selecting your country and entering your phone number.
6. You will receive a message from Viber. It will have the activation code.
7. On the activation screen, enter this code.
You are done installing Viber on your desktop. Enjoy using Viber on your Desktop.
