Video card Diamond Viper 770 Ultra
I have upgrading to a video card Diamond Viper 770 Ultra. That has different jumper configurations for AGP 2x and 4x (I have an Intel Pentium 440BX chipset mx 400mhx). Which I set for, is it 2x or 4x AGP?
The video card Diamond viper 770 ultra is more like the Nvidia driver and therefore it should be able to work on your computer. I do not think the jumper configurations will be different. Otherwise some of the specifications that you might need to know about this video card as follows:
With those details you should be able to download the right diamond viper 770 video driver for your computer.
-Chalk Talk
Video card Diamond viper Ultra 770 is compatible with your system. You can easily use it for upgrading your graphics. It uses NVIDIA Riva as a graphics processor and 32 MB video memory installed. It has a slot type of 4X AGP. The one you need to set for is 4x AGP, don't confuse it with any other.Â
Hope this helps you out,
