Video chat using Samsung Galaxy S2
Can you recommend a good video chat software for my Samsung Galaxy S2? I am already using Skype but I just want to try other softwares that are available in the market to compare which is the best.
You can use Google chat on your Samsung galaxy for Video chat. Google Talk video chat for Android is now available on Samsung galaxy s2. You can now use the Voice Chat application and can make video calls. This application can also use 3G and 4G and not just WI-FI.
All you need is a Google account. Go to Google talk application >> click on Video chat icon placed next to your contact name.
You can then video chat with your friends/ family. You can also use Quick. Quick helps you in Video chat, you can also Video mail. Sharing Video is also possible using Quick.
This application can also use 3G, 4G along with WI-FI. Video calling resolution is high as well. When you are not live for a Video chat, you can get Video mail. Only drawback that can be listed about Quick is it is poor at finding/ searching contacts having Quick. Fring is another Video chat option which you can use. You can use the same for group chat as well. Tango can also be used for Video chatting.
Hello Drey,
I think so far Skype is the best video chat application that you can use on the Samsung Galaxy S2. I also use Skype to keep in contact with my family as well as friends around the world I have never been disappointed by its services. Though I must say that sometimes connections can either difficult to call, or they could be very quiet and also prone to drop.
If you need to try other video calling applications then I think the following must work for you:
I have used these two and I found them to be impressive. You can go ahead and give them a try and see what the response will be like for you.
Hope this helps.
Carl
You can try Gtalk 1.3 for video chat on your Samsung Galaxy phone. Samsung has already deposed the inbuilt GTalk video calling on the recent Galaxy S2 firmwares. So you will need to use a third party application such as Vtok or to download and install it on a rooted device, please follow the steps below:
1. Download and then install the GTalk 1.3 installer on the market on your Android phone.
2. Install the application and then simply run it.
3. Select the Recommended latest version and then click Install to finish.
4. Gtalk Video option will now be available on your device.
You can also try ooVoo, Paltalk, Qik and a lot more software for video calling.
If you want to try other video chat apps for Android other than Skype, your Android phone already has one, the Google Hangouts app. Try running the app to see if it needs updating. Another app you should try is the Google Duo. Unlike Google Hangouts which is designed for group chats, with Google Duo, it is designed almost exclusively for one on one communication.
The Samsung Galaxy S2 is different from Samsung Galaxy S2 Epic. The Samsung Galaxy S2 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on February 2011 and released on April 2011 measuring 125.3 x 66.1 x 8.5 millimeters and weighing 116 grams.
It uses mini-SIM card and has Super AMOLED capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring TouchWiz UI 4.0. It ships with either Android 2.3.4 Gingerbread or Android 4.0.4 Ice Cream Sandwich upgradable to Android 4.1 Jelly Bean powered by Exynos 4210 Dual chipset, 1.2 GHz Dual-Core Cortex-A9 processor, and Mali-400MP4 GPU.
It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB. The primary camera supports 8 megapixels with LED flash, autofocus, and f/2.6 featuring face and smile detection, touch focus, geo-tagging, and 1/3.2″ sensor size. It supports 1080p video recording at 30 fps. The secondary camera supports 2 megapixels.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 3.0 with A2DP and aptX support; GPS with A-GPS support; NFC is optional; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, proximity, and compass sensors.
The pre-installed web browser supports HTML with Adobe Flash support. Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1650 mAh battery with standby time up to 710 hours on 2G and 610 hours on 3G. Talk time is up to 18 hours 20 minutes on 2G and 8 hours 40 minutes on 3G. It is available in black, white, and pink colors.
