Nur Islam
Posted on - 03/19/2012
I am using Total Video Converter and I boot registry code. It's working good but while I'm try to convert a .VOB movie file to .3gp on its default setting and click to start convert every time it's give me a error message called "Error while opening codec for output stream – #0.0". How can I solve this type of problem and how to convert .VOB to .3gp file?
Error while opening codec for output stream #0.0 – maybe incorrect parameters such as bit_rate, rate, width or height
OK
Video convert error while convert .VOB to .3gp
Hello Nur.
Based on the error message being returned by Total Video Converter, there's a problem with the codecs installed in your PC. Â Codecs can sometimes get corrupted by other installed codecs or other media converters that have been installed.
To fix the error, I suggest the following:
1. Â Uninstall all video converters that you have installed including Total Video Converter. Â
2. Â Run a registry cleaner. Â
3. Â Reinstall Total Video Converter.
If the above does not fix the problem, download and install K-Lite Codec Pack from here:Â
http://www.free-codecs.com//www.free-codecs.com/download/k_lite_codec_pack.htm
If the above suggestions still do not work, I suggest trying a different converter. Â I recommend Freemake Video Converter (http://www.freemake.com/free_video_converter/) for its ease of use and good output quality.
This software is not supporting such kind of conversion; you need to download vob to 3gp converter from here. Install this software and try to convert your files to 3gp with help of this.
