Video converter error when trying to convert
Hello Dear,
You have problems in converting video files. Here are some tips to solve your problem, just follow-
** Your converter software may have problems, may be it could blocked by your antivirus.
** Stop protection or unable protection when converting and then enable protection.
** If still problems occur then you need to use new software.
** Go to Google search, then write “format factory”, and the press the enter button.
** Download “format factory”
** Install the software.
** restart your computer.
** Now try to convert file to your desired format.
I hope your problem will be solved.
Have a nice day. Thank you.
Hi, I was having similar problem with my convertor too. I tried everything but it still wouldn't work, but then i tried downloading the "format factory" referred by Monte Mayor and it works very well. Thank you for recommending it.
