Video Does Not Play Correctly On Windows 10
I use Windows 10 on my computer. If I use my laptop for some time and then leave, come back again and play a video, the video does not play correctly. It plays the video by skipping frames. How can I solve it?
Answered By 0 points N/A #317987
You can adjust the FPS in the video software settings. There also may be a fault with the graphics card or display driver. If you have NVIDIA display card then, follow as below:
1. Go to Control Panel and find the NVIDIA Control Panel.
2. Click on 3D Setting>Adjust image settings with preview.
3. Click on “Use my preference emphasizing” option. Then, change the “Quality” and “Performance.”
Check if this works otherwise, you have to update the graphics card driver.
