Video Editor for compiling two or more videos and pictures
What is the best video editor that I can use for compiling my video clips and pictures at the same time? What are the steps on compiling it all? Please send me some ideas. Thanks.
If you are looking for a good video editor software for compiling your media files, try the Lightworks. This software has been used on the past Oscar-winning films. It is a Non-Linear Editing System (NLE) which is used for modifying digital video files in different formats such as PAL and NTSC. You can download it from the link below:
Download Lightworks Video Editing Software
You can download the installer for Windows 32 and 64-bit PC along with the installation and activation guide. Then install it on your computer. For a tutorial on how to use Lightworks, you can watch the video below:
[video:http://www.Youtube.com/watch?v=YRYNAvZJawQ autoplay:0]
This software is easy to use. When you learn the basic editing, it will be easy to import your media files and create your video in an instant. It supports various formats especially for Professionals such as MXF, QuickTime, AVI containers, ProRes, Avid DNxHD, Red, HD and more. It has a timeline that looks so uncomplicated but powerful than any other. It support drag and drop, default insert feature, replace and fit to fill edit commands. You can also change the clip speed, control your videos and track the volume levels, add effects and transitions.
You don't even have to worry on the frame rates, codecs and more. It also capable of trimming your video and it can modify the stereoscopic media just the same way you edit other media files. You can do it Side-by-Side, Checkerboard, Anaglyph and more. If you want to add images to your clip, watch the video below:
[video:http:www.youtube.com/watch?v=0mW2-utyzj8 autoplay:0]
If you want to learn more about Lightworks, the link above also includes the manual and some guides on how to use it.
